RE: Joe and Ed's Weedy FX26 Xtreme gassy boat. Mono hull
Looks like yous are having fun well done,about the not turning left welcome to monos.How to fix it sharpen the prop!! and offset the drive to the right 1/4" or you can shim the strut over a tad using a cpl of washers.Having the rudder slightly in front of the prop wont hurt turning i had mine set slightly in front on a cpl of mine and it didnt hurt at all.That said you dont want it like 1" in front of the prop but a touch or level is fine.How long is the rudder? if its too short then left turns will be even harder as the rudder will not be deep enough in a left turn.Make sure the props sharp and balanced that will reduce prop walk and improve the poor left turns .
Mart
