RE: Ignition system voltage
Reply from MVVS on the ignition voltage on the S unit.
Hello,
S ignition till 10V there is not problem. 11V is Top line.
Best regards
Lukas Chymek
Technical Support / Technická podpora
MVVS, spol. s r. o.
tr. Kpt. Jarose 35
60200 Brno
Czech republic
Bottom line is the S unit can take up too 11volts so a 3S A123 battery should be OK, fresh off the charger would be 10.8 volts.
The Pro unit can take up too 16volts so a 4S A123 battery should also be OK, fresh off the charger would be 14.4 volts.
Hope this helps all.
Mike
