Originally posted by MarkNovack
For me it is the follwing:
1. The dead prop has the least amount of thrust shortening the roll-out.
Actually that's not quite true Mark. A rotating propeller in the dimensions we use on pattern airplanes running below 2000 rpm actually produces more drag than thrust.. and becomes a very good brake. You just need a good idle.
-Doug
