RCU Forums - View Single Post - v-spec issues
Old 09-22-2008 | 09:35 AM
Bax
Default RE: v-spec issues
You'll need to check the piston/liner fit. After six gallons' worth of fuel, it's likely that the piston/liner fit is about worn out. That's a lot of running for an R/C car engine. When the piston/liner fit wears out, the idle and acceleration are the first to go.
