RCU Forums - View Single Post - Why do pattern guys do this?
Old 08-05-2003 | 09:55 AM
  #75
ini
Default Re: Re: Engine out landings
Originally posted by Acroman330
That's really good idea Bob. Since Chris flies JR I guess it's something that you can do on a 10X (which is what I have). Would you care to explain how to program something like that? That is really interesting Thanks!
This is really a great idea.
I have allways used the "kill before touchdown" method.
The reason was at first to reduce risk of injury. If you hit yourself (a sudden wind gusp etc.) the damage is a lot less without a rotating prop. Later I have used it to save props. At our field wind allways brings some sand on the paved runway. The less you run the engine the less abrasive it is to the prop.
Well, after reading this thread I reprogrammed my TX. Now I have a 3-pos switch in front for normal idle, 1800 1/min. Mid position is for low idle, 1300 1/min, and the last position kills the engine. It works like charm, it's almost like cheating, landing is so easy with improved braking. After landing the engine still runs, has never stopped during approach. If I want I can taxi it back, also I can add power if needed. The engine is OS 1.40RX .
I have Futaba 9 ZAP. I copied the normal condition, separated throttle trim for that, and voilá. I can trim idle for both conditions, other trims are combined.
Thanks, guys! It was worth reading this. You allways learn something.
ini
