RCU Forums - View Single Post - kyosho sukhoi
Thread: kyosho sukhoi
Old 03-17-2002 | 07:18 AM
davham's Avatar
davham
Default sukhoi
Dihedral (with one side of wing flat and the other end up, measured
up to the fattest part of wing bottom at tip): approx. 1-15/16"
Incidence with stabilizer at zero-
Wing root: +1/4 degree (plus or minus 1/4 degree)
Wing tips: -1 degree (plus or minus 1/4 degree)
Engine: +2 degree down thrust and 1.2 degree right thrust (This
can vary because of the two-piece engine mount.)
Center of Gravity: 97mm (3-13/16") behind the leading edge of the
wing where it meets the fuselage.
Center of Gravity Range: 7mm (9/32") forward or 8mm (5/16") back
Noteo Not, At Any Time, balance your aircraft outside this range.
Control Throws- High Rate Low Rate
Ailerons: Up & Down 3/8" (10mm) 1/4" (6mm)
Elevator: Up & Down 3/8" (10mm) 1/4" (6mm)
Rudder: Left & Right 1-3/16" (30mm) 3/4" (20mm)
REQUIRES: Engine: .40-.46 (2-stroke) OR .48-.53 (4-stroke)
I had a saito 72 on mine-very slow vertical. I now have a saito 91, is much better but still want a little more.
