RE: Raptor G2 Pulls to Left After Takeoff Help
heli tilt to the left is normal because your rotor is spinning clockwise all the time. It's important that you use a trainging kit because it helps the heli to prevent it from tilting to the left so your rotor won't strike the ground.
You should move the tail servo on the boom to offset the drifts.
Andy
