RCU Forums - View Single Post - Steering problem.....Please Help
Old 09-22-2008 | 11:22 PM
samguan
Default Steering problem.....Please Help
There' s some steering problem with my Ramunition.... When I turn, I can hear the cracking noise.... Also, when turning right... one wheel turns more than the other wheel. so basically... if I turn right, the right wheel turns to 45 degrees and the left wheel would only turn 20 degrees... any suggestions? When I turn left, both wheels are fine. I inspected the problem and found out that the arm that turns the wheel, the joint on one of the arms is a little loosen than the other one... I tried hard to push the joint back together, couldn't do it.. any suggestions.
