RCU Forums - View Single Post - Turbo prop help needed
Old 09-22-2008 | 11:51 PM
mr_matt's Avatar
mr_matt
My Feedback: (10)
Default RE: Turbo prop help needed
Hello,
The glow plug is either bad or not getting hot enough. Make sure at least 1/8 inch of coil is pulled out and that the coil is not shorted to the plug body. Start bumping the plug voltasge up, with a Rossi I would go straight to 2.6v minimum. You might also want to lower the starting gas percentage down 10% from wherever it is set now.
Regards,
