ORIGINAL: hannie
Hi everyone
Does anyone know how to set up Crow in a cularis. I have a airtronics rd8000. I currently have a y connection for the ailerons. plug into channel2.They said to activate spoilron function you have to plug ailerons into channel 2 and 6. but channel 6 is the flap connection. Just curious if someone has done this. Thanks Bruce
You are not activing flapperons. Flapperons are for planes that don't have flaps. Think of flapperons as "fake flaps". You have real flaps.
As Joedoe said, you MUST have the ailerons on separate channels. On my Futaba, ailerons are in Channels 1 & 7 and use an aileron differential mix to control and coordinate them.
Flaps can be on a Y cable, however, your radio may allow you to put each flap servo on its own channel too. My flaps are on channels 5 and 6, but again, that is on a Futaba radio. Airtronics uses different channel assignments. But they can be on a Y for crow.
