RCU Forums - View Single Post - Backwards loop
Old 09-23-2008 | 09:24 AM
darticus
Default Backwards loop
Don't know much about this but maybe someone can help.
Picture the plane flying away from you and you watching from the tail end. You than push the right lever on your radio full up.The plane dives down and under and continues to come up and with a little throttle it pulls up levels off and flies straight. Well when it pulls from under and you give it that throttle it aways seems to come up tilted to the left. That means the left side tipped down. Why is the left side tipped down. I have trimmed until I blue in the face. Would it be a weight problem, balance? Suggestions needed! I am flying a Bug. Thanks Ron
