RE: Backwards loop
darticus:
Its usually one elevator moving more than the other, can also be unballanced from side to side. Its tough to play with ballence when you stick on a battery after each flight. Each time you replace the battery, thangs can get all goofed up. Unfortunately, there are a lot of things that can cause your bird to snap in a tight loop and you just have to play with the problem until you cure it, including CG. Enjoy
