RCU Forums - View Single Post - Prop Problems
Old 09-23-2008 | 08:30 PM
Gray Beard
My Feedback: (-1)
Default RE: Prop Problems
If you can post photos of how you have it set up that would be A big help. It should be the back plate first, the prop, prop washer, prop nut, spinner adapter nut, spinner and then the spinner screw that runs through the center of the spinner and screws into the adapter. Hope that helps you. The screw holding the spinner doesn't need to be torqued down very tight or you can break out the center of the spinner.
