RE: remote glowplug igniter
check out sullivan products, they make glow systems that will do what you want.
i've made them before using a remote glow driver from hanger 9, use a C battery box from radio shack, and either a switch to turn off or i used a micro switch and set it up so that when you pull your throttle back it turns on your glow.
there are some on the market that plug into your reciever and actually pull off your reciever pack and are set up using your computer radio. expensive but less work to set up.
