RE: Ebay Rafale...?
Turn on your radio while holding down and select at the same time.
Now hit the down button until you get to the [wing type] screen.
You need the "Delta" mix. This is the same as elevon/taileron.
You probably need to reverse channels 2 and 3. (assuming you have your tailerons plugged in the same as me)
