RCU Forums - View Single Post - Starting Engine... What's the "proper" way to do it?
Old 05-24-2003 | 01:09 PM
Hossfly's Avatar
Hossfly
Default Starting Engine... What's the "proper" way to do it?
1. Have the plane plane situated to where the person holding the plane for me can easily hold the plane back without having to reach across the table.
XXXXXXX
7. Have assistant pick up plane, get tx off bench, extend antenna and warm engine up before takeoff.
Am I reading this right?
You start the engie on a bench/table? Then pick up the machine with a running engine and transport it somewhere?
Believe me, I am definitely NOT one of those guys that are self-certified *safety-experts* however it appears you are setting up a dangerous situation.
I firmly believe that the engine should be started at the point from which you are to start the taxi-out.
While reaching over a spinning prop for any reason is not a recommended procedure, I do it all the time. OTOH, I never position myself or anyone in the extended plane outside the prop's arc, during the initial start phase.
When training beginners, I am rough on them to:
(1) Be certain that the entire area in front of the model is clear of cords, loose tools, etc that could be sucked into a spinning prop.
(2) Have the transmitter within adequate position allowing a quick shutdown of the engine if needed.
(3) Never get hurried. Watch everything, and stay CLEAR of that prop.
