RE: More prop explanation needed please
When you start from the middle of the engine's torque curve............
If you increase diameter..........
The rpm will decrease, the airspeed range will lessen and become more constant, airspeed might decrease slightly both high speed and low speed, idle might improve, prop should pull better through turns, acceleration and deceleration should improve but cover less speed range
If you decrease diameter..........
The opposite of the above
If you increase pitch.........
The rpm will decrease, the top speed should increase, speed at idle should increase, acceleration and deceleration should lessen, the airplane will probably lose speed in turns more
If you decrease pitch...........
For all..........
When you increase rpms by whatever means, engine heat should increase as should fuel consumption.
When you decrease, the opposite of the above.
