RCU Forums - View Single Post - Problems with upgraded CX2
Old 09-24-2008 | 10:11 AM
evdreamer
Default RE: Problems with upgraded CX2
Your motors are probably to far away from the main gears, so the gear mesh isn't correct. If I remember right there isn't much adjustment available for the motors on the CX2. So you might have to drill the motor mounting holes closer to the mainshaft so you can get the motors closer to the main gears.
Nick
