RCU Forums - View Single Post - Ebay Rafale...?
Old 09-24-2008 | 03:41 PM
  #168
Squirrlybird
Default RE: Ebay Rafale...?
Glad you got it set up.
I guess I'm just going to set the throws to what "looks" good and dial in a lot of expo.
I have heard that the roll rate is really fast, but lots of elevator helps with the take off. Based on these reports, I am dialing in a lot of throw and counting on expo to save me on the first flight. After that, I will be better suited to set it up to my liking.
I will probably try 100%-130% throw (in the transmitter) and 50% expo. Be sure that when setting your throws, that you make both the aileron and elevator identical as this function only controls one servo and not the mix. However, setting expo controls the entire mix for either aileron or elevator, so you will not need identical settings in the expo menu. I would prefer to set the throw to an inch or centimeter value of deflection, but I'm sure it will be fine doing the trial and error method. Hopefully I wont have so much of the error part.
Unfortunately, its too windy here for a maiden today. Maybe things will calm down by the weekend.
