RCU Forums - View Single Post - OS 50 engine cutoff when throttle applied
Old 09-24-2008 | 04:11 PM
Skarn
Default RE: OS 50 engine cutoff when throttle applied
pe reivers: I tried what you suggested....I had to borrow a battery one since I do use a field box one with wires.....but I'll be damned if I finally did get it to hover for about 10 seconds before it completely quit again. But then I had problems even getting it to start after that and I was frustrated so I put it away for the night. So I was going to replace the glow plug the next time I mess with it. But if it's too rich, wouldn't it sputter first then quit, not quit suddenly.....I though too lean would indicate the sudden cut?
Skarn
