RCU Forums - View Single Post - Building a HouseofBalsa P-51
Old 09-24-2008 | 09:27 PM
ExperimentalAviator's Avatar
ExperimentalAviator
My Feedback: (15)
Default RE: Building a HouseofBalsa P-51
Mike,
I think your engine choice is great! I built this kit back in the late 80's and stuffed a Super Tigre 45 ABC into the nose. I used four standard servos with the stock aileron push/pull tube setup. I did fully sheet the wing and fiber-glassed the center section.
The four bladed prop and spinner was for display only, and I removed the muffler for the pictures. I did install a semi-scale tailwheel that fully swiveled. It flew great and handled the extra weight with no problem.
I believe that your idea of using two aileron servos is great, but I doubt that you will need the flapperons.
Mike
ID:	1040430   Click image for larger version
