ORIGINAL: xxSLiMxx
ORIGINAL: spoonrc
Mmmmm all my goodies came today!
$300 worth!
Here they are, I'll post finished pictures when I have put it all together.
Also when you guys mean shim your diffs do you mean shim them so they move with some force and are pretty rough when turning the wheels (like clicking)
Shim them so they move with some force. What tires did you get? What are the other parts aswell? (small pic, i cant really see them all)
Umm, moabs, hpi rims, 49T spurs, OFNA slide linkage, OS .18TZ, diff housings and duratrax vented and lightened flywheel which I am having trouble fitting.
ORIGINAL: KeithjV
You dont want to feel clicking. If you do then they are too tight. You want to take up any play there is so that the gears mesh well. They should turn smoothly when you spin them
are you able to show me a diagram of where the shims should go? I used all the bigger shims inside the diff, there is no play until I force it but when I move the drive train the gears are rough because they are meshed to each other tightly.
