RCU Forums - View Single Post - Throttle position for level flight vs. landing?
Old 09-26-2008 | 12:54 PM
Mr67Stang's Avatar
Mr67Stang
Default RE: Throttle position for level flight vs. landing?
ORIGINAL: gregoryda
My Stik is set up a bit nose heavy until I get used to it. I guess, based on what you said, I try adjusting for level flight at 1/3 or less throttle and live with holding bit of down elevator or trim on full speed flights. Sound like the right thing for me to do? DG
I would not enjoy flying like that. I do not want to have to fight my plane to fly the way I want it to. When you say "and live with holding a bit of down elevator" it sounds like you don't want to either. The better ballanced a plane is, like your stick or my Funtana, the more neutral the elevator will be when trimmed for level flight. This neutral elevator position means no fighting the plane and your manouvers will look better and be easier to perform. A properly set up plane can make any novice look good in the air.
