RE: Throttle position for level flight vs. landing?
Just out of curiosity, but what size prop are you flying this plane with? Perhaps a shallower pitch and larger diameter would suit you better. The larger props, when the engine is at idle, will give you a bit of a speed brake effect and help you bleed off speed even as you bleed off altitude.
