RCU Forums - View Single Post - Cline Regulator ???
Old 05-24-2003 | 01:16 PM
Willy RDRC
Default Cline Regulator ???
I am placing a Cline regulator on a Moki 2.1. Can anyone give me guidance on how to connect the various fuel/pressure lines? The backplate on Moki has been tapped and a nipple has been installed. Muffler used is a Bisson Pitts muffler.
Do I run a pressure line directly from the backplate nipple to the fuel tank with the fuel line going from tank to Cline regulator? If I do this, do I have any pressure line from the muffler to the fuel tank...or is the needed pressure in fuel tank sufficiently provided by the line from the Moki's backplate? Or, do I splice the 2 pressure lines with a "T" fitting which then attached to the fuel tank?
The instructions that came with the Cline regulator were not as clear as I'd like. Thanks to anyone who can assist.
