RCU Forums - View Single Post - New DBC Module
Old 09-26-2008 | 05:54 PM
YHR's Avatar
YHR
Default RE: New DBC Module
I tin the ends of the wire with solder so that helps with the fazzled look. I thought about a two pin connector, but thought that would be too easy to plug in wrong. These connectors work OK, as in reality the DBC will most probably stay in the tanks I put them in. The module just gives me the option to move them around a bit.
