RCU Forums - View Single Post - Fliton Element 170 ARF build
Old 09-26-2008 | 08:53 PM
  #42
patternflyer1's Avatar
patternflyer1
Default RE: Fliton Element 170 ARF build
Tail wheel mounting is straight forward. You take the pieces from the bag, and install them where you feel they need to go. I measured it when I did it, but I forget the measurement. I will try to remember to update with a dimension to drill the hole. For the rod mount on the rudder, I used a piece of plastic hinge that I cut off of one I had laying around.
ID:	1041480   Click image for larger version
ID:	1041481   Click image for larger version
