RE: Channel Mixing Problem
If the two fuselage elevator servos are mounted roughly in line with the elevator horns simply runing the pushrod on one side to the servo output arm below the servo and mounting the pushrod on the output arm on the opposite side above the servo will eliminate the need for either a reversed servo or a reversing (Y) cord.
John
