RCU Forums - View Single Post - *&%$£& engine problems!!!!
Old 09-27-2008 | 09:33 AM
ceecrb1's Avatar
ceecrb1
Default RE: *&%$£& engine problems!!!!
ok some pics..
first shows the front of the engine.
There was a LOT of fuel escaping from here after I took the coweling off the plane. The cowel inside was totaly soaked with fuel.
Is this normal?
the last 2 show the needle valve problem and solution, in the last photo you can see where the threaded section of the nipple is still inside and where the nipple broke off.
ID:	1041667   Click image for larger version
ID:	1041668   Click image for larger version
