RE: *&%$£& engine problems!!!!
2 strokes are very easy to operate but are suscebtable to dirt,are you using an inline fuel filter?it could be clogged,also that carb looks awful big for a 52 could be causing a fuel draw problem unless you are using a pump or muffler pressure.also bkdavy suggestions as to the needle valve are also correct.have you tried running on a test stand?
