RCU Forums - View Single Post - Coroplast glue options
Old 05-25-2003 | 12:48 AM
ajvpb
Default Coroplast glue options
Yes I did read all the way through and I do have poly glue for that purpose. So, then just to make sure, I should use the goop for the hinge points, right? Also, with the elevator torque rod, is that used so that you only have to hook up a control horn to one of the elevator halfs? If so, will a 2-56 pushrod work well? Thanks for your help and thanks for taking the time to put up your plans.
Alex
