RE: Here's A Simple & FREE First Foam Build Plan! (Part 2)
calvio,
Like Saucerguy notes, there is no reason to worry about your prop hitting the ground on landing with the SO. The only props I have broken were trashed when I hit the ground with power on. Using the SO as an AP platform is a perfect match. This plane will fly very slowly and you can handle plenty of extra weight and drag. The Aiptek 5 in 1 camera works great and the FlycamOne 2 would work great as well.
I have built the SO with both one and two aileron setups. The single aileron works just fine. Using two may give you better control in very slow high alpha flying but it is marginal. No matter what you do with the ailerons you will not get a very fast roll rate out of this plane but it loops like no tomorrow.
Do you have a pic of your F-22 to post. Or a link to a thread?
Cheers,
