RCU Forums - View Single Post - Problem Programming HS-5645 Servos
Old 09-27-2008 | 03:06 PM
Joe Counter
Default Problem Programming HS-5645 Servos
I'm trying to use two HS-5645MG servos via Y-cable on two elevator halves. One servo needs to be reversed and the neutral point offset a little. I have a HFP-10 Programmer (green sticker coded 06.11) and NIB HS-5645MG servos (blue sticker with white leaf in center coded 08.04). I followed the instructions carefully (RESET first then CCW, then set Neutral and End Points via EPAneuFS program). Neutral point = -10, L-end = -210, R-end = +190. The result is very little servo arm travel, only about +/- 12 degrees, although the receiver signal range to the servo is from 1152 to 1841 microseconds. If I reset the servo it works OK. If I change the direction to CCW and leave the neutral point and end points alone it works OK (but the neutral point is off beyond the range of linkage adjustment). I tried various L and R end points and leaving them unchanged but nothing works. Any idea what's up?
