RCU Forums - View Single Post - Throttle position for level flight vs. landing?
Old 09-27-2008 | 03:35 PM
exeter_acres's Avatar
exeter_acres
Default RE: Throttle position for level flight vs. landing?
ORIGINAL: jaka
Hi!
Always trim for full throttle!
sort of....
if you trim for full throttle and then bring the throttle back to idle and the attitude of the plane changes... then there is probably a thrust issue.
you should not need to change an airplanes trim dependent on throttle positions....
