RE: Angel S EVO Build Thread
The elevators go straight across. Meet both the stab tips the same. You can see that the elevator is way off neutral (with required trim) when siting from behind. The incidence measurements would tell me that one of the surfaces is way off. Jeff's measurements to the front and rear of the wing show that it is close to neutral with the top of the fuse (canopy base). Less than .4 mm difference which is probably close to where mine are based on my wing incidence measurement. So that would mean my stab is off almost 2 degrees. Hard to believe as that is quite a bit. I guess the stab could be cut free and refitted but that would be a PIA. I wrote to both the manufacturer and the online source I purchased it from and ghaven't heard from either.
Stuart
