RCU Forums - View Single Post - Removing World Models Hinges
Old 09-27-2008 | 11:47 PM
Craig-RCU's Avatar
Craig-RCU
Default RE: Removing World Models Hinges
ORIGINAL: 4000686798
Has anyone removed Wolrd Models metal hinges before?[sm=confused.gif]
I was thinking about recovering one of their planes but those hinges look tough to remove![:@]
Hi, I converted the flaps on my WM Zero 60 to split flaps and had to remove the metal hinges of the existing flaps first. I found that the metal hinges were hot glued in and came out fairly easily by holding a soldering iron to them for a bit. I don't know if this will work for all World Models planes, but epoxy softens too with heat if yours are epoxied instead.
