RCU Forums - View Single Post - Low End Tune !!
Old 09-28-2008 | 12:12 AM
JohnW's Avatar
JohnW
Default RE: Low End Tune !!
Yes, that works and has been my prefered way to deal with naughty glows for years. I reccomend it. One comment, you don't use a tach or ear to set low end anyway as you implied. You check throttle transition and let the engine idle for a bit to see if it loads/leans. This 'traditional' test should still be done after resetting the low side via the glow heat trick.
