ORIGINAL: jimiengine
HI!
WHICH IS THE DIFFERENCE BETWEEN THE GEOMETRIC AND THE EFFECTIVE COMPRESSION RATIO???
THANKS
Geometric compression ratio are measured volume between TDC and BDC + volume of compression camber.
Effective compression ratio are measured volume between TDC and from the exhaustport are closed (twostroke engine) or intake valve (4 stroke engine) are closed + volume of compression camber.
See the link:
http://www.modelenginenews.org/faq/index.html#qa13
