RE: Problems with upgraded CX2
I have also upgraded the motors to the extreme se180's. I have not had this issue with the gears stripping. Like others have said before. Make sure there isn't a gap between the the motor gears and the main gears. Unfortunately, they won't make the aluminum upgrade for the main gears, because of the issue w/ crashes. If the gears don't give in a major crash then you run the risk of ruining the motors.
