RCU Forums - View Single Post - mixing
Thread: mixing
Old 09-28-2008 | 08:37 PM
Planedev
Default RE: mixing
I think he wants to mix throttle and steering, unless you are goingto substitue your throttle channel withyour elevator channel(you might need to remove the spring on the elevator channel) i think the only other way to get ard this is to buy a vtail mixing circuit (very cheap) and connect it to your throttle channel and your aileron/rudder channel. That way you got both forward motion and turning controlled by the 2 props.
