RCU Forums - View Single Post - Aileron Differential on a Bipe
Old 09-29-2008 | 04:11 AM
ntsmith
From: Bishop\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'s Stortford,
Default RE: Aileron Differential on a Bipe
Guess your right as others had said. If using a two servo wing set up the amount of diifernetial can be simply programmed in with a JR tranny. I would suggest though, that you should also consider having to learn co-ordinated rudder/aileron turns.
