ORIGINAL: foundryratjim
Ok, I started to assemble mine... The motors bolt pattern is wider than what the holes in the shroud are drilled. I am using the recommend 420 motors from e-flite. Any body else have this problem?
Yes... I think everyone has that problem. Greg Covey talks about it in his build thread
http://www.rcuniverse.com/forum/m_76...tm.htm#7728664
As was mentioned above, you can widen the holes on your fan w/ a drill bit.
Good luck!
- Charlie
