RCU Forums - View Single Post - Raptor G2 Pulls to Left After Takeoff Help
Old 09-29-2008 | 08:59 PM
yadac123
Default RE: Raptor G2 Pulls to Left After Takeoff Help
the pitch is the dip switch to unlock the pitch curve. adjust the curve so that 0 at low stick. The eagle 50 doesn't have trottle curve adjustment.
the connector with the single wire is the sense adjustment. You can connect that to aux 2 channel so you can adjust the gain on the radio menu.
Andy
ORIGINAL: wayshwing
BRD -
Left drift is normal especially if youre first learning to hover. The faster you get airborne, the less you will notice left cyclic drift.
Lack of lift could be pitch setting (not enough positive pitch vs. headspeed) or pitch curve is wrong and needs adjusting.
Andy -
Does V1 control pitch curve and V2 control throttle curve? Which DIP switch locks/unlocks them? Where would the normally be set?
Also, the gyro has 4 wires. 3 wires are on one conn, which goes to RUDD. Where does the singe wire connect to?
