RCU Forums - View Single Post - RAM Autostart ECU Question
Old 05-27-2003 | 12:28 PM
747drvr's Avatar
747drvr
Default RAM Autostart ECU Question
Well, I'm glad you've had good experiences with all of your RAM equipment. I won't go on about all the problems that I've had with RAM 500 SN 070 because it's a very long tale but I will comment on at least my B version ECU.
I have seen it start the engine nicely and have it idling in 20s. Great ! For every start like that I've had 10 mis starts. IMO opinion this ECU wants to do everything RIGHT NOW and if any part of the start sequence is slightly out of step it does not work. The much more gentle , deliberate autostart sequences use by other motor and ECU manufacturers is a lot better.
When I finally sorted out the mechanical and combustion chamber issues with my RAM I also switched over to a manual start FADEC. Trouble free starting EVERY time.
