side effects of having engine mounted upsidedown compared to sideways?
Yep, take the time to lean out the low end and you should be fine. Lean it out so that the rpm only drops slightly when you remove the glow plug igniter. Don't go too lean that the engine quits when you go to full throttle from an extended idle.
