RCU Forums - View Single Post - coving a built up wing
Old 10-01-2008 | 10:48 AM
Rodney
Default RE: coving a built up wing
DaRock is correct, most aliphatic glues work this way. Put on a thin coat, let dry, mate the two surfaces and add heat. Hold in place until cool. A very good joint. This also often works well on loose covering, coat the area to be rejoined, let dry then iron down the loose covering.
