RCU Forums - View Single Post - I retired the trainer.
Old 10-01-2008 | 01:26 PM
jib
Default RE: I retired the trainer.
ORIGINAL: opjose
. . . converting it to a tail dragger ( easy to do except for the tail wheel )
I am installing Dubro semi-scale rear gear on my new Ultrastick. Check it out.
http://www.shopatron.com/product/par...161.5181.0.0.0
Jack
Note - I went one size larger so it would handle the grass field better.
Also, on the UltraStick, we had to run the springs back to a small piece of dowel in the back lower corner of the rudder, as there isn't enough room to attach the standard fitting at the front lower corner of the rudder and have the clearance to move both the rudder and elevator completely though their ranges.
