The charger i use is by Mulitplex. It has the capability to charge just about any pack and is 100% worth the price. You will also need an AC/DC power suply which u can buy at Radioshack, Frys Electronics or the like.
This is the Multiplex Multicharger Battery Charger.
FEATURES: Charges 1-14 cell NiCd, 1-14 cell NiMH, 1-5 cell Lithium Polymer or
Lithium Ion and 1-6 cell lead acid batteries
Constant current/constant voltage for LiPo and Li-Ion
Illuminated digital LCD screen displays battery type,
charge/discharge mAh, voltage and charging time
LCD screen will also display error messages for out-of range input
voltage, incorrect connection or reversed polarity, poor battery
condition and internal errors
Adjustable charge current from 0.1-5.0A
Charge, discharge and cycling functions
INCLUDES: Multiplex Multicharger Battery Charger with input leads and alligator
clips, output leads with alligator clips, instruction manual and
extra set of plugs
REQUIRES: Power supply capable of delivering 11-15V DC (HCAP0250)
SPECS: Input Voltage: 11-15V
Battery Type/Cell Count: 1-14 cells NiCd and NiMH
1-5 cells LiPo and Li-Ion
1-6 cells lead acid
Charge Current: 0.1-5A
Discharge Current: 0.1A-1A
Trickle Charge Current: 0-250mA
LCD: 2 lines 16 characters illuminated
Charge Termination Method: Delta-Peak for NiCd and NiMH,
Constant Current/Constant Voltage for LiPo and Li-Ion
Charge to Discharge Cycling Max: 5 cycles ending charged or
discharged
Length: 4.5" (115mm)
Width: 3.3" (84mm)
Height: 1.1" (29mm)
Weight: 9.9oz (280g)
jxs 8/11/05
ir/jxs
– If you need more information, use these Multiplex resources – Web Site:
http://www.multiplexusa.com/
Phone: 858-748-6948
Postal Address:
Multiplex
12115 PAINE STREET
POWAY, CA 92064
I bought it from here:
http://www3.towerhobbies.com/cgi-bin...&I=LXKSY1&P=FR
