RE: What is the difference between Team Associated TCR5F and TCR5R?
the tc5 is the first version. The diff between the tc5r and tc5f is the tc5f has a different top deck and foam tires with the kit. When running carpet wth foam, you want the chassis alot stiffer than you would for asphalt. now you can run a rubber car tire on carpet and it works well also, you just have to do more adjustments
