RCU Forums - View Single Post - Engine issue
Thread: Engine issue
Old 10-02-2008 | 09:59 AM
warheadforever's Avatar
warheadforever
Default RE: Engine issue
If you mean that it takes a millisecond for the RPM do drop after you let of the gas, then yes, that is normal. If it takes a few seconds, then you are getting something called "run-on" which is were you have the low end needle set to rich. The fix, lean the low speed needle a little bit.
Hope I helped.
Warheadforever
